SW dwg NOT updating properly, not saving properly, edrawings fault?
Good morning,
I am in a very weird situation and I do not know what on earth to do about it. I have designed a frame, by making the individual square tubing pieces as parts, and then assembled them in SW. Everything went swimmingly. Then I made a drawing, and everything was fine. All was well. Then I had to move two components closer together in the frame, so I did, and I added 4 holes. I saved the assy, and it looked just as it should. No problems saving. The drawing updated correctly, saved it, printed it. Now our secretary opened it up in eDrawings, and then made a pdf. for our manufacturing department. And it showed no changes. The new dimensions I put in there were still there, but the parts were not there. The hole call-outs for the new 4 holes were there, but not the holes. I have opened the assy many times, closed everything, opened them in different order, and no matter how many times I change the drawing to how it is supposed to be using properties>show default, or last-saved, whichever, it changes the view then reverts when I open it independently again. What is going on? How on earth am I supposed to get it to just represent what the assy looks like? Please, any insight would help.
RE: SW dwg NOT updating properly, not saving properly, edrawings fault?
