Nozzle Reinforcement
Hello I am designing a pressure vessel on saddle supports with nozzle at shell and heads. The nozzle is located at knucle region of the torispherical head. I´ve calculated the nozzle geometry and it don´t need a reinforcement but my question is: Is there a section on the code that suggests nozzle reinforcement when it is located at knuckle region of the head ?
RE: Nozzle Reinforcement
Richard1977,
            The knuckle region of a vessel is highly stressed and placing a nozzle in that region is not recommended. In fact PD5500 does not allow a nozzle to be placed within the knuckle region and specifies a distance within which a nozzle is not allowed.
Ricky...
DSB123 is correct. The knuckle is the weakest part of the head
A nozzle in the knuckle is a bad idea -- this is banned by PD5500 but, to the best of my knowledge, ASME is silent.
about this.
This has been discussed before
http://www.eng-tips.com/viewthread.cfm?qid=276049&page=1
http://www.eng-tips.com/viewthread.cfm?qid=264450&page=11
http://www.eng-tips.com/viewthread.cfm?qid=127987&page=1
and studied elsewhere..
http://journals.pepublishing.com/content/pl64572657652356/
You might be able to justify your configuration with FEA
-MJC
Hello. In PN-EN 13445-3 in section "7.7 Nozzles which encroach into the knuckle region" are informations aobut weakened in  knuckle region. But rules are recommendet for Kloepper and Korbbogen ends.
