How import NX assembly into Teamcenter
When I try to import an existing NX assembly into a new .prt model file, it says this may not be done. You kidding me??? A NATIVE NX assembly and component model files cannot be brought from a remote directory into a Teamcenter-launched session of NX5? That can't be right. Help - thomasleeclark
RE: How import NX assembly into Teamcenter
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
In this case the clone command will run.
On the numbering tab you can select the Auto Generate option in the Import Numbering row.
