Aluminum Plates for Fixtures & Jigs
We use 6061-T651 aluminum plates (1" to 1 1/2" thick) plates for simple jigs and fixtures. We are looking for a lower cost alternative - if there is one. The strength properties are not critical, but the material should be at least fair in machinability. Does anyone have any suggestions?
RE: Aluminum Plates for Fixtures & Jigs
Drill or waterjet a bunch of lightening holes if you like.
Mike Halloran
Pembroke Pines, FL, USA
MIC 6® Aluminum Cast Plate
ht
I've seen K100 used where the primary function is a light weight mounting plate.
http:
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
