single start worms
single start worms
single start worms
Hi
looking for a single start Diametral Pitch worm calculation from measurement over three wires to circular tooth thickness.
& from circular tooth thickness to measurement over three wires.
Heres the data if some one can give an assit.
# of starts~1
DP normal~32
PA normal~20 deg.
lead Angle~ 2 deg 23' 30" RH
axial pitch~ .09826
Pitch Diameter~.749
root diameter~.680-.660
lead~.09826
wire dia~.054
Measurement over wires .826-.824
Mfgenggear
RE: single start worms
using my gear program I calc .0488 normal ctt.
I would like a second check.
mfgenggear
This is what I get.......pretty close to your result.
Dimensions are metric.
Reference profile 1.25 x 0.38 x 1.0 ISO 53.2 Profile A
Addendum coefficient                           1.000
Dedendum coefficient                           1.250
Generating angle                              20.000°
Normal Pressure Angle                         20.000°
Helix angle at reference diameter             87.611°
Lead angle at reference diameter               2.389°
Reference diameter                            19.025
Tip diameter                                  20.612
Tip form diameter                             20.612
Root diameter                                 17.040
Generating Profile shift coefficient      0.0000 - 0.0000
Manufactured root diameter                17.040 - 16.982
Normal tooth thickness                     0.000 - -0.021
Theoretical pin diameter                       1.326
Actual pin diameter                            1.372
Diameter at contact point                     19.112
Chordal tooth thickness at pitch diameter      1.246
Actual chordal tooth thickness            1.246 - 1.224
Axial Tooth Thichness                          1.247
Actual tooth thickness                    1.247 - 1.226
Reference chordal height                       0.791
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
Gear Cutter
Than you for your response.
My calculation above was nominal.
my high & low CTT is as follows.
.0491/.0483 which rounded off.
Thanks & Take Care
Mfgenggear
