tapping feed rate
tapping feed rate
may be a dumb question...but should the feed rate for a tap (inch per revolution) be the pitch of the tap? ie a 3/8-16 tap should always have a feed rate of 0.0625 inch per revolution?
thank you
thank you
RE: tapping feed rate
But normally the tap should take care of the feed itself as soon as the thread is started.
Benta.
Ben Loosli
There are people who swear by the slower tap feed such as looslib but over my years of programming I have never found a difference.
Lots of shops use rigid tapping successfully.
Software For Metalworking
http://closetolerancesoftware.com
Powerhound, GDTP T-0419
Engineering Technician
Inventor 2010
Mastercam X4
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
YMMV
The Manufacturing Reliquary
http://cmailco.wordpress.com/
16 threads per inch
1/16 is yes .0625 pitch or distance per revolution
if you turn the tap at 100 rpms then
100 times .0625 is 6.25 inches per minute feed rate.
