Linear dimensions on a geometricly toleranced print
If a print has a section view with a linear dimension
describing a feature, does the view need to be set up for measurement purposes according to the geometric datum scheme or can I just measure it as a independent feature
because of the linear dimension callout?
This print has a combination of both linear dimensions and geometric callouts on the print.
