Accelerometer springs material
I hope this is the right forum area to post this ...
I'm learning about analog accelerometers which use springs to suspend the moving mass inside them. I've looked but can't find so far what the material is for the springs. I have a hunch it would need to be a material that's temperature resistant so deviations in temp. don't throw the spring rating off and it would also have to be dimensionally stable during temperature variations too.
Any guidance on this is much appreciated! Thanks.
Bret
Miami,FL USA
RE: Accelerometer springs material
Even then it dilutes the quality of the answers you will get
B.E.
Would you happen to know any suppliers of those types of springs? Their size would be pretty small at about 1/2" or less.
Bret
Miami,FL USA
