Submodeling by input file
Hi
i've remotely started a submodeling analysis, then i quit from cae and after pre.exe finished i get this error:
"Abaqus Error: The executable /opt/abaqus981/6.7-1/exec/standard.exe
aborted with system error "Illegal memory reference" (signal 11).
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
Socket error: (111, 'Connection refused')"
So i tryed to re-run the analysis by the .inp file, but i get another error:
"The result file containing the global model file was not specified. The abaqus analysis cannot be executed"
How can i specify the global model in the input file??
THX a lot to everyone help me :)
