Replace TS member with welded plate
What are the implications from switching from a Tube Steel member, and using steel plate to build the section as a weldment assembly (other than the lower yield stress).
RE: Replace TS member with welded plate
Higher Cost of fabrication.
Weld quality.
Appearance.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
