Problem with surface loft
I'm trying to render a 3D model of a rat spinal cord using Solidworks 2010, and am having problems doing surface lofts. I've used AutoTrace on each cross section, then fit a spline, and split each one into equal number of segments. For some reason, I have no problems lofting between some sections, but some of them I can't get to go, despite trying different segment configurations, guide curves, simplifying the spline, etc. I've attached my part. I've gotten the 'outer border' to work just fine, but am hung up on 'grey', only being able to loft between some of these sections. Please help!
RE: Problem with surface loft
Dan
www.eltronresearch.com
Dan's Blog
Thanks for the quick response.
No thank you.
Too big to download for my virus scan to handle.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Will play with it some more later...
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Please see the attached image and the google document link. The file is rolled back and zipped to save space. I hope this helps.
htt
Rob Stupplebeen
Out of curiosity what are you doing with this model?
I hope this helps.
Rob Stupplebeen
one of the 2D layers:
[img http:/
my progress thus far:
[img http://
Rob Stupplebeen
