placement of object for render in Photoworks
I'm sure that this was discussed before, but can't find it.
I need to do a render of an object (small assembly) and if I try to use any of the default "Presentation Scenes", my object keeps levitating in space, far from what the nearest surface or ground resides. With the basic and studio scenes the object is touching the "ground" level, if there is any reflection, the surface of the ground reflects back, no problems. I tried everything that came to my mind, but no success. Am I on impossible mission?
(SW2010 SP2.1)
(SW2010 SP2.1)
RE: placement of object for render in Photoworks
Dan
www.eltronresearch.com
Dan's Blog
Either way,see http://robrodriguez.com/wordpress/ for oodles of tutorials.
If I create an additional part that should not be visible on the rendered image, suppressing or just hiding it would still be a part of the assembly. How do I "ground" it? I mean, how do I issue a command to that part or feature to lock it to the surface that doesn't really exist in the background when the Presentation Scene is used? As far as I understand it, the selected scene is just an image that is "wrapped around" the object/part/assembly...
Dan
Dan's Blog
Thanks, now it's clear.
I'll test that right away. Anyone cares for a star?
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
