Level tank transmitter fluctuations
We have a fuel oil tank that is approximately half full (300,000) litres.
This tank is only there for use as a standby, should our gas supply become interupted.
The tank is measureing the level using 3 rosemount level level transmitters. Looking at PI trends over a period of ten days (any ten days) the level measurements 'change' by a few thousand litres.
The trends show peak high levels at approximately 4pm each afternoon, and peak low levels at approximately 4am each morning.
can anyone help explain this please?
http:/ /img266.im ageshack.u s/img266/8 184/fueloi llevel.jpg
http:/
RE: Level tank transmitter fluctuations
With the sheer volume of liquid contained within this tank i do not see how ambient temperatures can alter the level indications so quickly (12 hours each way)
It is a real strange one for me, as the tank has not used the fuel consistently for years, or routinely in the last year.
To me, the trends should be flat lined
There is no temperature measurement measurement on this tank, but one must guess that the temperature would be somewhere around ambient.
(I cant get my head around this, as if you have 1 kg column of liquid, and this expands in temperature throughout the day, you will still only have that 1kg column of liquid, even if the actual volume varies.)
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
NC
But there are some variables that can affect pressure transducers. As xnuke hypothesized, a different working fluid in the sensing capillaries (or contamination in them by moisture or air bubbles) could introduce errors. Also, the configuration of the transducer's reference inputs and tank venting configurations could introduce some errors. In fact, the expansion of air (and resulting pressure) due to ambient temperature changes would be greater than that of the fuel oil. So I'd be looking at tank venting or bubbles in the tubing.
Check your sensor lines for sediments, check your isolation valves to see if they are all open, check ths installation to assure it follows good instrumentation practice.
Oil can grow things and oil tanks can rust even with oil in them.
Does the sun hit the sensing lines at the same time of day?
My guess you instruments aren't responding to tank leve but sensing pressure in the connecting tubing.
Spray water on the lines when the pressure peaks.
