Light Aircraft Design
I have been thinking of building a scaled down version of a WW2 fighter aircraft large enough to carry one person.I have access to scale drawings which are mainly used for aeromodelling for the basic shape. Where do I start with the process of working out the necessary calculations required in a project of this sort.
RE: Light Aircraft Design
2. become good friends with one or more aircraft designers
3. hang out where homebuilts are being built and flown.
4. other aircraft have been built as scaled replicas. read about them and the design process.
5. have you built model airplanes? I mean real flying ones?
There's another place to begin learning!
have fun
Jay
Jay Maechtlen
Why should it be more important to satisfy your curiosity.
Can you help with my original, abeit simplistic question?
Most homemade airplanes start out as bigger scale models of the actual aircraft one wants to build, and with at building mode that is as near to the big one you want to make.. and one the for sure..you will find that on some subjets things have to be a little of scale to make it fly the way it is supposed to. Often tailplane and elevator have to be a little larger to compensate for lower flying speed.
That way a lot af practical things are solved in the cheap way. and belive me that is a part of the fun doing it all by yourself.
Claus
Do a research in :
www. landings.com
in the homebuilt sections.
If you want to design it yourself , it will be a long learning process and could result in disaster.
Just my 2 cents worth.
Tim
Sorry for my english.. is not my native language.
1. Justify design choices to the FAA. Design calculations, etc.
2. Demonstrate meeting that design in practice. Pix, test samples, etc.
(If selling)3. Demostrate a quality system to insure you are building to the approved design.
I sell PMA (approved) Piper sunvisors - small, harmless devices, easy to build, but a royal P.I.T.A. for quality system and adherence!Best of luck!
We specialise in projects like this, l can give you some tips if you are seriously interested.
john@rcs-aviation.com
