EEPROM being destroyed during processor programming
Hi
We have a very occational problem that results in a M25P16 EEPROM being destroyed during the programming of the associated dsPIC30F6015 microcontroller.
We have monitored the voltages around the EEPROM and all are within the normal operating voltage limits during the programming.
The board in question is one being used for development, and has had the EEPROM changed twice in the last 4 months. The board, installed in a test rig, has been re-programmed probably about 50 times without problems.
Has anyone else experienced this type of failure??
RE: EEPROM being destroyed during processor programming
Are you unable to access the data anymore, are certain cells no longer programmed to their original levels, etc.?
Dan - Owner
http://www.Hi-TecDesigns.com
So as far as we can determine, at the moment, the first pages, at least, are un-readable
TTFN
In addition to a hundred other possibilities, if you "monitored" the voltages with a meter then you could easily miss short duration events that might be occurring during a programming cycle. Unless you used a digital oscilloscope with cleverly adjusted triggers, the monitoring exercise may not have proven anything.
TTFN
Does your dsPIC application only read, or does it do some erasing and writing? If it's only the first few pages that are bad and the rest of the device is ok, then maybe they are getting worn out from too many erase/write cycles.
Glenn
TTFN
<written by someone currently fighting with dual small/large-page NAND Flash algorithms for a bootloader> Oh how I miss the days of individually addressable element EEPROMS...
Dan - Owner
TTFN
Anyway, the point of my making a distinction was because serial flash is block-eraseable and often survives fewer write/erase cycles than serial EEPROM.
Glenn
While EEPROM technology has poorer W/E endurance than EPROM, it's still pretty good, and should be nowhere near only 50 cycles. But, it's possible that the OP has purchased some bad parts. However, it's usually unlikely that all bits in a block would all be identically failed within a single cycle, since there's still some variability within the process, even at that small a scale.
That, in of itself, would suggest that there's some sort of intermittant F/W or S/W bug, that either accidentally causes the block to be munged, or causes the programming cycle to be shortened or aborted altogether.
TTFN
Dan - Owner
The operating code is stored exclusively in the dsPIC. The M25P16 is used only as a data store.
There are 4 M25s in the array.
Particular operating parameters are stored in the first few pages of the M25, (M0).
The loading of the operating parameters is done through a serial link when the code is running normally. These pages are occationally written to updating the parameters during any particular run.
It is only after a code reload that the M25 becomes "unobtainable". I am having some code written to determine if it is the first few pages of the first block, or the whole of the first block, or if it is the whole 32 blocks.
Replacing the M25P16 deemed M0 cures the problem
Are you sure your clock rate is compatible between the two devices? I've seen latch-up type issues on some devices when they get clocked too fast and destroy themselves (this was a motor driver, so it may not be applicable but it did come to mind).
John D
The test rig comprises of a production chassis, (of what is essentially an inertial platform), and a stand that just varies the inclination and azimuth of the chassis.
The processor, during programming, is powered from a lapdog which also drives the Microchip Real Ice programmer.
It is difficult to see how ESD could be a problem.
I was wondering if there might be some sort of bleed through from the 13V programming voltage, (applied to the dsPIC), and the SPI port. I have not observed any spikes during programming.
Dan - Owner
The aluminium chassis is approx 950mm long by 50mm dia. There is a fairly substantial BLDC motor on one end. The chassis sits on an alloy frame which is approx 1400mm long.
The whole of the test rig, that the chassis is attached to, is non-magnetic.
It is not possible to connect either the serial, (RS232), lead, (for power), or the programmer to the processor board without touching the chassis for orientation. Any personal static charge would be disappated in the mass of the chassis/test rig.
There is no plastic involved in the design.
Dan - Owner
Are the other memory blocks affected in any way? Can you fill the unused memory blocks with a pattern so that you can do more diagnose on the next failure?
TTFN
There was one instance of failure when a board was on an antistatic mat on a bench. All static precautions were observed. Once again the processor was being re-programmed
"There is an exposed central pad on the underside of the VFQFPN package. This is pulled, internally, to VSS, and must not be allowed to be connected to any other voltage or signal line on the PCB." (not likely an issue)
"Resistors R (represented in Figure 4) ensure that the M25P16 is not selected if the Bus Master leaves the S line in the high impedance state." (curious...)
"Deep Power-down (DP) ...can also be used as a software protection mechanism, as in this mode, the device ignores all Write, Program and Erase instructions." (useful feature to implement?)
Sometimes these sorts of problems are eventually resolved using obscure information that would never in a million years be provided. In other words, things we can't see from here.
Glenn
Stuck how? C is an input.
TTFN
I know it is an input, but SCLK has been seen stuck high or low.
One of the first things that the code does, after setting ports etc, is to read the first pages of M0, which contains operating parameters. The memory array contains only data, not operating code.
It is at this point that the code hangs. The data is not read, and the code waits until it is read. If the page contents were corrupted, by having cells "damaged", data would still be read, and the code would continue to run.
If SCLK is stuck in one state the processor cannot clock the data, so keeps trying.
I suspect that SCLK is damaged. Replacement of the M25 is the only cure. The M25 is the SO8 part.
Interestingly, there are 4 M25s in the array, but only M0 is affected.
The board has had the serial lead plugged in many 100s of times without causing problems. It is only the act of programming that has "killed" the M25
Seems like there's quite a bit of useful info there to help track down the problem.
Dan - Owner
I don't understand how, or why.
It only happens during a programming operation. The board has been programmed probably 70-80 times, and I have had to change the M25 twice, and with several months between changes.
I removed the board from the test rig yesterday and have been playing with it on the bench. I programmed the board some 50 times today, no failure occured.
Interestingly, M0, (the only chip to be damaged), is furthest away from the processor and at the end of the SPI chain. M3, the closest to the processor, does not fail.
There is also an AD7656 ADC attached to the SPI bus, but this is sited the other side of the processor. This device is also unaffected.
TTFN
I assumed that something was happening on the SCLK line, and I was monitoring that line as I was programming.
Nothing showed.
TTFN
I'm with IR, you seems to be chasing the wrong dog's tail, and the info coming to light recently is starting to scream electrical issue... input lines don't fail on multiple chips without a serious upset event causing it. If it is static buildup, you'll have a tough time tracking it down as any attempt to monitor the line in question means a connection to ground through the test equipment (even if it's a relatively high-impedance).
Dan - Owner
I agree that it is an electrical issue of significant proportion. But, why only when programming, and possibly only after 40(ish) code loads.
Why only M0, when there are 3 other devices connected to the SPI?
One of my posts wondered if there was some sort of bleed through when the processor I/O was put into HiZ state during programming, but this would not explain M0 only.
On the very few occasions that there has been a failure there has been no difference in the proceedures adopted for programming.
The serial lead has been connected 100s of times without problem. It, surely, must be programmer/programming related.
Again, have you independently verified that the parts are tango-uniform?
Do you have sufficient records to identify:
> operator(s) for each programming run
> time of day of each run
> etc.
TTFN
I am the only person programming the development kit, programming could be several times in a day, and then not for weeks. Typical of any design development.
The time of day could be anything between 08.00 and 17.15H.
There is nothing identifiably different with the programming proceedures/methods
It seems, currently, that the most likely immediate COD is some sort of destructive signal on the clock pin. However, an odd observation is the stuck high on the clock pin. The clock driver should be able to overcome most normal loads. To get that pin stuck high would imply essentially a short to Vcc.
If so, that's relatively easy to test, even on a loose part, since you only need Vcc, Vss, and the clock pin. If you have to, you could get someone to solder some thin wires to those 3 pins. Hook up Vcc and Vss to a power supply, and set your DMM to current mode and connect it between clock and Vss. If you get a massive, i.e., >>100 uA, then that confirms that the input is seriously zapped.
If so, then it's definitely a handling or circuit problem. A circuit problem would require you to monitor the pin with an oscilloscope capable of triggering on a large voltage threshold, say, 5V, and you'll simply have to keep trying to blow up a part on the programmer and see if you can get a trigger event.
TTFN
Is SCLK shared by all the serial flash devices? Also, did you really see some that were stuck high and some that were stuck low? Or do you just know that they were stuck, but didn't know which way?
Are there any other pins on the flash that are damaged?
Glenn
TTFN
Unfortunately parts removed were dumped, so no postmortem.
We have tried repeatedly programming the processor, some 50 times, whilst monitoring the SCLK line with a digital scope set to trigger at 4V. Nothing failed.
A number of boards have been pulled for the development process from the boards destined for field testing.
There were early failures over a period of several months. These failures manifested themselves as loss of communication. There were two failures. The processors were suspect, (as the failures occurred after programming), and changed. The boards still failed to work. These boards were binned, as it was deemed not worth chasing the problem.
When the problem next occurred more time was spent trying to resolve the issue. The problem was traced to the inability to read M0, causing the code to hang.
M0 was changed and the board then worked, and has been working for some 6 months.
A further board was taken into the development process. In the last 4-5months it has had M0 changed twice. In the latest instance the SCLK pin was definately low. It was suggested to me that on the previous occasion SCLK was high. This I cannot be sure of.
So, three definate M0 failures, and two highly likely.
May, repeat, may have found problem.
The 0v return on the programmer/board lead was intermittant at the programmer end.
Resistance varying from 5 to 76R. New cable 0,5R.
Only time will tell.
Thanks for all you help
Roger
How long is your cable? You can build up a lot of voltage on an unterminated cables as it swings through the air. Once you plug it in that voltage surges through your circuit.
The serial lead is always plugged in first.
One interesting thing is that the SCLK pull down resistor is physically sited next to M0.
I can very vaguely see a mechanism for failure, but it is clutching at straws.
During programming there is pulsatile current flowing in the 0V return to the programmer. If that line is high(ish) resistance, and maybe with some inductance, then possibly programming current could flow down the RS232 gnd.
This may possibly cause a spikey voltage to be developed across the pull down resistor directly connected to M0, stressing and maybe killing it.
The other memories might be protected by track inductance.
As I say, straw clutching at it's maximum
Dan - Owner
An induced EMF in the ground leads are usually less than 1 V.
TTFN
I guess I will now have to wait until the next occurance.
Thanks for your suggestions
Roger
If M0 is the only one blowing, then the chip select is the only unique line for that chip. I would also check the actual board layout to ensure there is nothing connected to the DNC pins of the chips etc. Do not rely on a schematic drawing.
The whole of the digital section runs from 3V3. There is +/-5V supplies for the analogy bits.
There are no DNC connections on the SOIC8 version of the M25P16.
Just M0 failing is the confusing bit.
I'm not sure of the SCLK 'stuck'. If there is hardware damage to the M25P16 clock input, then try adding a small input resistor such as 10R to the SCLK input and CE input so that you can see if the inputs are sourcing fault currents.
Like you say, there must be some definite reason for only M0 to be affected so far. Usually power-up transients are where damage like this are liklely to occur.
could a long unscreened track be grabbing local RF tuned to its length , Mobile phone / TAXI pickup .
They stop people transmitting on oil-rigs !
In many instances a robust reset signal is all that is required to keep the system from running, but in others it may be necessary to take even more precautions. A watchdog on the power supply should be sufficient but check with the manufacturer or test it yourself. Failure to do so can result in some very odd behavior...The system works great until you shut it off, then intermittant issues pop up depending on where you were in the code when you start shutting down and how quickly you actually turn off.
I have seen systems with bootcode programming capability take themselves out during these transients. We could never see how we hit the code, then the mfgr informed us that at some voltage level the branch instructions no longer operated reliably and we just blew through the bootloader and erased program memory.
