Screws versus Nails
Screws versus Nails
I need to attach a wood rail to a post for a fence. Someone suggested using a Kreg pocket hole jig that uses screws. Do screws have more or less shear strength than nails? Does anyone recommend using screws over nails or vice-versa?
RE: Screws versus Nails
What a screw will provide is withdrawal resistance for a longer time if the fence is exposed to the weather. If you want to make the fence more than decorative, I would recommend screws, rather than a nail. I can tell from personal experience that a worn 6D nail in a fence is weaker in withdrawal than a Lab retreiver puppy...
