pressure/force need to push a standart LED button?
hi i hope my Q belongs here
does any1 know how much presure (psi) or force (any units)
is needed to activate a LED button?
if noboy knows that it'll suffice to know the pressure needed to push a keyboard key.
thanks
thanks
RE: pressure/force need to push a standart LED button?
OF is an acronym for Operating Force. The force needed to be applied to the Actuator to move from the free position to the operating position. The operating force is given in N or Nm.
As an example, http
shows OF Max of 250 grams.
See http://www.lmgtfy.com/?q=led+pushbutton+spec+sheet
for more
