Frames - Help please
Hi All,
Anybody experienced with the frame command.
I have a project that requires lots of frames to be made from profiles similar to RHS (or SHS). But with up-stands of various types.
If all the sides of the frame are of the same type there are no issues and everything works fine.
The 2 profiles I have attached make a section of a window. J6 is for jambs and head, J5 is for the sill.
Normally I create these as individual parts and assembly, but I thought I would give the frame command a chance.
The problem is that Jambs and head are fine but when I add the Sill it places correctly but doesn't mitre.
The profiles have had all the extras removed and are simple sketch/protrusions for the test and may not be fully constrained. Please note, J5 Sill is in the correct position
The Frame command doesn't seem to have a tutorial or any real information in help.
There have been posts in the past between Beachcomber and Don Young which were helpful.
http://www.eng-tips.com/viewthread.cfm?qid=254368
Are there any real web tutorials out there? I've had a browse but most are very basic.
Any Help would be appreciated
RE: Frames - Help please
I think you are asking too much of the frame tool in this instance. The mitre point isnt obvious and therefore beyond the scope of this tool.
As you say, the tutorials are basic - like the tool.
There is new frames functionality in ST3 but as yet no info is available on exactly what has been added.
Tony
Sometimes you may need to extend parts then trim with an assemby cut.
Sorry I can't be more helpful but I'm on holiday this week (back Thurdsay).
Can you post an image of what you are trying to achieve and I'll have a look when I come back.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Please find attached a PDF of the frame and Step files of the 2 profiles.
No rush
Ken
Ken G.
http://grundey.blogspot.com
I haven't tried this out yet, but I think I messed up with the profiles J6 should have been J2 which is very similar except there is no outer upstand.
There is no reason why the method shouldn't work for J2 also
bc.
Quadro FX4600.
In the end I went back to my old tried and tested method.
I create a master generic sketch profile with all the combinations. The actual profile has a lot more to it than the basic ones I sent through.
I then create a generic assembly sketch of a frame, with new reference planes at the centre of each sketched line representing a Head, jamb or sill, positioning the sketch of the generic profile at the center of each these planes. Using create in place method, I create a protrusion of each profile linking to the end points of each line. I then mitre (er) the ends.
Finally I create a generic draft.
This way by changing the original sketch O/A dims I can create as many frames as required. I hope that makes sense.
I thought I could skip a few steps using the frame command.................maybe by ver 1001
Cheers
Its a while since I used frames but from what I remember you might need to create it in one frame and then change the cross-section of the odd one as Ken describes.
Other than that it can be difficult to get members of different frames to mitre properly. I've sometimes had to use assembly cut-outs.
One thing though Karmoh, have you got the 'Coping on non-mitred joints' option checked - it might make a difference?
You could also try switching the butting options around.
Frames can be a bit frustrating and the commands need quite a lot of work by Siemens - hopefully ST3?
The good news is only one more week on this Catia V5 crap then its back to Solid Edge.
bc.
Quadro FX4600.
