What is the longest galvanizing tank for an I-Beam available?
What is the standard (typical) size of a galvanizing tank? 30'? 40'? for wide flange beams.. Thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: What is the longest galvanizing tank for an I-Beam available?
If the architect isn't happy with the line visible from double dipping than the beam will require additional splicing.
No matter how big the galvanizing bath is, there will always be someone who wants to galvanize a larger piece of steel.
Thank you..
I don't know much about statistics, but I do know that if something has a 50-50 chance of going wrong, 9 times out of 10 it will.
Only way to know is to call, most of them are very helpful since they want the work.
ht
http:/
