String Arrays
String Arrays
Does anyone know a command to convert a string array to a single string (I am passing the file path to the run_journal.exe program and I need to make the array of strings into a single string).
Thanks.
Thanks.
RE: String Arrays
Some pseudocode might be something like this?
CODE
for i = 0 to ubound(strarray)
superstring = superstring & strarray(i)
next
RE: String Arrays
foreach {index value} [array get myarray] {
if {![info exists stringvar]} {
set stringvar $value
} else {
append stringvar $value
} ;# foreach
RE: String Arrays
