Fitted splined connections
I hope to be in the good area .
I working on fitted splined connections DIN 5480 - 28 x 1 x 26 x 9H 9g.
I have problem with inspection dimensions. The shaft and hub could be control with the dimension over or between measuring circles. I know to define the values M1 and M2 following the public standard DIN 5480 and by calculs ( I used the equations of QTC web site). I don't know how to define the tolorance for this values.
Could you help me?
In add, I need to do the same thing with the span measurement of teeth.
Sorry for my english.
Could you help me?
