Vfd
Vfd
I have voltage coming into my vfd but nothing coming out and the screen is blank. Is there an internal fuse or is the vfd just bad?
RE: Vfd
What about a speed reference?
What model is it?
RE: Vfd
RE: Vfd
Don't know enough about the PF drives to know if that's a separate board or a part of a monolithic board now. If it's the latter, it's hopefully still under warranty because the cost to repair will likely approach or exceed the cost to replace.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
RE: Vfd
Above that hp, you may have some parts of the drive that are serviceable. Larger drives also tend to have internal fuses which often are replaceable.
How about a little more information.
RE: Vfd
Neil
RE: Vfd
