Why does changing two leads change the rotation of a 3 phase motor
Why does switching two leads on a 3 phase motor change the rotation?
RE: Why does changing two leads change the rotation of a 3 phase motor
You may understand it better if you draw a wheel and note three points on its circumference 120 deg apart. Name them A, B and C. Imagine it being rotated by three forces A to B, B to C and C to A. If you interchange any two points of application, you will see the direction of wheel's rotation will reverse.
Rafiq Bulsara
http://www.srengineersct.com
Rafiq Bulsara
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Bill
"Why not the best?"
Jimmy Carter
