Four 3d plots in one coordinate system
Hi
I have 3 surface plots and one vector that I would like to plot in the same coordinate system.
The situation is the following (axis scales are predefined and fixed):
1) Each plot by itself works fine
2) If I plot one surface plot and the vector the vector is reduced to a dot
3) If I plot a second surface plot to an existing one mathcad does the "divide by zero"-error.
Any help or work around appreciated!
