Equipment for Boric Sulfuric Acid Anodize
I'm researching the differences between Cromic Acid Anodize and Boric Sulfuric Acid Anodize for a process change we are currently planning, and the hardest thing to compare is differences in factory equipment between them (type of tanks, electrical system, auxiliary equipment, etc...)
Both processes performed under MIL-A-8625F requirements, for aeronautical aluminum parts, do any of you know what are the specific machinery differences between them, or both could be performed using the same type of equipment?
Also, it would be very nice if you could provide me some links to companies that make this kind of equipment, as I don't have much idea about who are the top and most widespread manufacturers in this field.
Many thanks in advance for your help!!
