Seawater Heat Rejection - Venturi Nozzle
I have a project that is using a sea water system for heat rejection for a building and it requires a venturi nozzle to ensure adequate mixing and reduced temperature difference (between discharge water from mechanical plant and sea water).
Has anyone used a venturi nozzle before, or do you know of a good supplier/manufacturer that I could go to to get more information on the product?
Thanks.
Thanks.
RE: Seawater Heat Rejection - Venturi Nozzle
