Loop feed 43.8 kV pad mounted oil filled transformer
I need help from any engineer who has experience working with 43.8 kV power distribution system in Alabama in terminating 46 kV class loop feeder cables to a padmount tranformer. Can you list tranformer and switchgear manufacturers or furnish a link?
Thanks. PGBENGR.
Thanks. PGBENGR.
RE: Loop feed 43.8 kV pad mounted oil filled transformer
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
They will fix you right up.
Rafiq Bulsara
http://www.srengineersct.com
