Wide Band O2 sensor response to missfire
In another site we have a debate going on about a miss fire where a rich mixture suddenly shows lean on a wide band as it loses power for a short interval then shows rich again as it regains power.
This is during a dyno tune on a Honda with a roots blower.
They are trying to decide if it is momentary spark breakdown or a hiccup in the fuel map. The map shows no abnormalities on the laptop.
Does completely unburned fuel show rich or lean on a wide band oxygen sensor.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
RE: Wide Band O2 sensor response to missfire
Since an O2 sensor is essentially comparing the amount of O2 on two sides of a diaphragm (one side in the exhaust stream, the other in the outside environment), you could theoretically shove a baby down the tailpipe and it wouldn't effect the sensor's reading. Bring in a bunch of air, squirt fuel into it, but forget to ignite the fuel, the O2 ratio is going to look (nearly) like 1:1...
Dan - Owner
http://www.Hi-TecDesigns.com
OK, I didn't think I was going to smile all day -- so thanks for turning it around!!
By the way, Pat, I agree that it'll momentarily spike up showing really lean if you don't use any of the oxygen because of a misfire. The sensor responds really fast, but I'm not sure how the engine controller will handle it.
Good on y'all,
Goober Dave
Both guys are correct, the reading will show a lean spike.
MS
Pat
for site rules
