Air Compressor Receiver Testing
We are looking at moving a 80 GAL T3 Ingersoll Rand air compressor setup from one site to another. It has not operated in about 5 years. What requirements are there to ensure it is still fit for purpose? Is a pressure test and NDT required?
RE: Air Compressor Receiver Testing
We will be visually inspecting the tank once we get it moved and the mechanic takes off the compressor for servicing.
I'm not familiar with pressure vessels. What code do air compressor receivers fall under? ASME Section VIII? Is there a section that describes what is required?
I suggest that you purchase a new 80 gallon tank
These tanks are very competitivly priced, widely available
Here is a good place:
http://hansontank.com/horizontal-airreceivers.html
My opinion only..
-MJC
The Inspector will decide if you should use it or not.
if you think the tank is defective, do not use it.
on the other hand Ingersol industrial put up a v ery good product (heavy duty tanks)
and 5 yrs in storage should not be totally bad. The bottom of the tank may be corroded and UT check is advised.
Code: Nationnal Boar Ispection Code NIC, and Jurisdiction
I California CAL-Osha /DOSH inspects. and it is ilegal to operate w/o a permit.
