import/open dwg
import/open dwg
import/open dwg
I tried both importing and opening the attached dwg that I pulled off a tooling component site. It was empty, although certain levels showed an object count. I tried unblanking(show) and select all but still nothing. I tried opening in a different system and the solids showed up no problem, from which I then exported a parasolid.
Since I have what I need its not a big deal, just curious if anyone else can open.
Ray S
NX 7.0.1.7
www.appliedprecisionproducts.com
