Sharper wireframe bitmap output.
NX6:
When outputting bitmapped images of wireframe from Model view I'm getting jaggies on the diagonals. I've played with anti-aliasing in NX but of course that's only affecting the display. I've done it before but can't seem to remember exactly what I changed... Any ideas?
Here's a sample of two images one from the last project and the new one on the right. It's bolder and "jaggier".
RE: Sharper wireframe bitmap output.
Bill
Preferences -> Visualization -> Visual
...and in the section titled 'General Display Settings', sub-section 'Session Settings', toggle ON 'Edge Emphasis'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I use a dual 19" monitor setup so I moved it to one monitor then fit the view. I changed the line fonts of the models to thin.
I set ON 'Edge Emphasis' as you mentioned.
It's much better. Not like a plot but ok (it is a bitmap afterall). The biggest fix was going from the large dual monitor screen size to the single followed by the thin font.
That all said I've had really good results with pdf output but this clients setup spreadsheet only takes bitmaps.
Bill
Raj
NX 5.0.6
That seems to help on screen display only - not the bitmap output... but thanks.
It's tricky. The part is 10' long so by the time it's viewed as an 8" x 6" image detail goes away. I would have thought exporting from my larger dual screens then scaling it down to fit on the page would work better than exporting from the single smaller screen. Perhaps I'm missing the image math...
It works ok for now.
Bill
