Embedded tolerances?
I have a drawing view where I am calling out hole locations using basic X and Y dimensions in a table using the dimension references (ie. &d192). My problem is that some of the dimensions show up with limits dimensions and others show up just fine. I can't turn off the display for all tolerances because I have other dimensions that need it. Is there somewhere in the model itself where the tolerances are embedded, because I haven't specified default dimensions for the hole locations anywhere. Any ideas. Thanks.
Kendall
Kendall
RE: Embedded tolerances?
Try selecting the individual dimensions in the table that have tolerances, select to turn it red, right click, properties, and you should be able to edit the way that dimension is displayed (i.e. as a basic dim).
If you cannot select the dimension in the table, you might need to show it on the part to edit it, then erase it to show it in the table again.
Dave
