AMS 5629 specs for PH13-8M0 material
hi eveyone,
this is my first post in the forum.
i am searching for AMS5629 spec.i searched everywhere on the internet and couln't find it.Can someone help me?
RE: AMS 5629 specs for PH13-8M0 material
AMS specs cost about $30 to $80 (US) each.  Your best bet on the cheap is to find a MIL spec for that material, though I don't know what the crossreference is.  Do you just need to know the composition?  That information is usually available with a simple web search.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
SAE AMS5629 can be purchased directly from SAE for $63.00.  Here is a link to their website:
http://standards.sae.org/ams5629e
If you just want to know a little about the material, its composition, etc., then look at the manufacturers that produce this grade, such as Cartech, Corus, or Latrobe:
http://cartech.ides.com/datasheet.aspx?E=51&;FMT=PRINT
http://www.corusgroup.com/file_source/StaticFiles/Business%20Units/Engineering%20steels/13_8ph.pdf
http://www.latrobesteel.com/assets/documents/datasheets/13-8_Mo.pdf
thanks a lot guys
Also this is a MIL-HDBK-5/MMPDS material, so most of what's needed for design (and, to a degree, manufacture) is in there.
