Delivering Bad News to a Client
I'm sure most of us have been in that position when we've had to pick up the phone and deliver some form of bad news to a client. Just wondering how others deal with these situations.
Any thoughts or tips welcome....
RE: Delivering Bad News to a Client
Rafiq Bulsara
http://www.srengineersct.com
Rafiq Bulsara
Tobalcane
"If you avoid failure, you also avoid success."
This is a fairly general question, as each project and problem are unique (as are the clients).
TTFN
Having some kind of mitigation plan as IRstuff says probably helps. However, there is some news so bad that it will take one heck of a mitigation plan to comfort them.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Start with any good news there might be. For example, "so, Mr. Client, we tested the prototype and it performed as we expected. Now our challenge seems to be getting that same level of performance up to the factor of safety as outlined in your specifications. We have reviewed the data and believe this will require....and estimate the cost to be around..."
Do not say, "Mr. Client, I have bad news. The prototype blew up into tiny shards of shrapnel at 98% capacity, well short of your specification of 130%. It's gonna cost a butt load more to get it to perform at that level and I have no idea how much time it might take."
"If you are going to walk on thin ice, you might as well dance!"
Be honest. Provide enough information so they believe you and understand what happened and why.
Don't wait to long but try to get all the bad news together. One big punch is better than a little one everyday.
Understand that the guy on the other end of the line has to to take the news to his boss. Give him the confidence that you can solve the problem so he diffuses the bosses anger instead of deflect the bosses anger at you.
Tell him honestly, simply, kindly, but firmly
Don't make a big production
Don't make up an elaborate story
This will help you avoid a big tear jerking scene
(Lyrics from the song Popular by Nada Surf)
-- MechEng2005
"Bad News Early = Good News"
Turns out it's a great motto.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
