Explode Dynamic Blocks
My dynamic blocks are taking up way too much space in my drawing. I have 2 dynamic blocks, each with 30 definitions or so - pipe flanges and valves where the dynamic block contains all the sizes and styles we use. At first I thought this was a great idea but now my drawing is 20 Mb or so and it is too unwieldy. I think that the hundreds of insertions if these blocks has done this. Ideally I would like to run some command that strips all the definitions out of the dynamic block instances and leaves only the size and style that was selected. In my perfect world, the remaining objects would be a block with the selected size and style being the block name. Any ideas out there for this?
RE: Explode Dynamic Blocks
