burn templates
burn templates
burn templates
I need a better way to create burn templates. Currently, i use the wblock command and add .dxf to the file name so that our pattern torches will recognize the file. I have to manually "z" move to elevation 0, elliminate overlaps, and convert to primitives.
What I'm looking for is code that will allow window selection, convert all entities into primitives (ie. circles lines and arcs) eliminate overlaps, and move all entities to elevation 0, then dxfout to a specified directory, then repeat.
Any ideas?
RE: burn templates
Try cutting and pasting this Lisp program. I grant that I have played with it but don't routinely use it. I generally save it as a DXF file and then inmport it into FastCAM
www.fastcamusa.com
ΓΏ
;    CNCPATH.LSP
;    Revision Date:    1.0   31 March 1989  Origional release
;                    1.01  20 April 1989  Added loading routines (cosmetic)
;                    1.02  28 June 1989   changed format to XYZ from bandit
;                                         added code to show progress of CNCOUT
;                    1.03  26 July 1989   Separated XYZ words in output with
;                                         spaces.
;                    1.10  26 Sept 1989   Added error handling function,
;                                         fixed minor bug in axis removal
;       Programmer:    Tom Blough (CIS ID# 76137,3211)
;           System:    AutoCAD Release 10 c2 (10/26/88) IBM PC
;                    AutoLISP Release 10.0
;  These LISP routines will convert a CNC program in XYZ
;   format to a 3D-Polyline in AutoCad where the path may be
;   edited.  The edited Polyline can then be converted back
;   into an XYZ compatible ASCII text file that will need
;   only minor editing.
(prompt "\nCNCPATH V1.10 -- A CNC utility by Tom Blough (c) 1989")
(prompt "\nLoading CNCPATH .")            ; show that we are loading
(setq    true nil
        false 1
(prompt ".")                            ; update loading status
(defun cncerr (mesg)
    ;    This function replaces the Autocad error
    ;    handler while our routines are running.
    (if (<> mesg "Function cancelled")
        (progn
            (princ "\nThe folowing error has occurred: ")
            (princ mesg)
    (setq *error* olderr)                ; restore autocads error handler
    (prin1)                                ;  and exit cleanly
;    CNCIN
(defun findchar (string begchr endchr / tempstr char pos b e)
    ;   This function locates the
    ;   first character whose ASCII value is between
    ;   the ASCII values of begchr and endchr, and
    ;   returns its interger position in the string.
    ;   If no matching characters are found, the
    ;   function returns NIL
    (setq tempstr string pos nil)
    (setq b (ascii begchr))
    (setq e (ascii endchr))
    (if (> b e)
        (progn
        (setq e b)
        (setq b (ascii endchr))
    (while (/= tempstr "")
        (setq char (ascii (substr tempstr 1 1)))
        (if (and (>= char b) (<= char e))
            ;found letter
            (progn
            (setq pos (1+ (- (strlen string) (strlen tempstr))))
            (setq tempstr "")
            ;not a match, so check next character
            (setq tempstr (substr tempstr 2))
    (eval 'pos)
(defun parsepoint (fname vertex / done line start tempstr end found point)
    ;  This function reads lines from the open file
    ;   until it locates x,y,z values.  It then
    ;   constructs a point using those values and
    ;   returns the point.  The function returns NIL
    ;   when it reaches EOF.
    (setq done false)        ; reset the coordinates and flag
    (while done
        (if (setq line (read-line fname))    ; get a line from CNC file
            ; not EOF
            (progn
            (setq found false)                ; reset found flag
            (setq line (strcase line))        ; convert the Alpha chars to upper
            ; search for X coordinate
            (if (setq start (findchar line "X" "X"))
                ; found a value
                (progn
                (setq tempstr (substr line (1+ start)))        ; find end of number
                (if (setq end (findchar tempstr "A" "Z"))        ; any more letters?
                    ; truncate string at the next letter
                    (setq tempstr (substr tempstr 1 (1- end)))
                (setq found true)
                (setq vertex (list (atof tempstr) (cadr vertex) (caddr vertex)))
            ; search for Y coordinate
            (if (setq start (findchar line "Y" "Y"))
                ; found a value
                (progn
                (setq found true)
                (setq vertex (list (car vertex) (atof tempstr) (caddr vertex)))
            ; search for Z coordinate
            (if (setq start (findchar line "Z" "Z"))
                ; found a value
                (progn
                (setq found true)
                (setq vertex (list (car vertex) (cadr vertex) (atof tempstr)))
            (if (not found)
                ; found one or more coordinates
                (progn
                (setq done true)
                (eval 'vertex)
            ; EOF encountered
            (setq done true)
(defun C:CNCIN (/ name file vert)
    ;  This function reads Bandit coordinate data
    ;   from a user specified file, and converts
    ;   it into an Autocad 3D Polyline.
    (setq olderr *error*)                    ; save old error handler
    (setq *error* cncerr)                    ; point error to our handler
    ; get a CNC file to work with
    (setq name nil)                            ; reset name string
    (while (not name)                        ; loop until valid filename
        (setq name (getstring "Filename and extension of CNC Program: "))
        (if (not (setq file (open name "r")))    ; does file exist?
            ; file not found
            (setq name (prompt "CNC file not found\n"))
    ; we now have the CNC file open
    ;  lets begin our polyline, and loop, creating
    ;  verticies, until our parsing function returns
    ;  a nil indicating that it has reached the end
    ;  of the file.
    (setq vert '(0.0 0.0 0.0))        ; set starting verticie to the origin
    (command "PLINE")
    (while (setq vert (parsepoint file vert))
        (command vert)
    (command "")            ; finish out the poly command
    (close file)            ; done with file so put it away
    (setq *error* olderr)    ; reset error to autocads handler
    (prin1)                    ;  and return to AutoCAD cleanly
    CNCOUT
(defun getpoly (/ tpath)
    ; This function queries the user to select the CNC path.
    ;  It checks that the selected entity is a polyline.
    (setq tpath nil)
    (while (not tpath)
        (while (not (setq tpath (entsel "Select a CNC path polyline: ")))
            (prompt " None found.\n")
        (setq tpath (entget (car tpath)))
        (if (/= (cdr (assoc 0 tpath)) "POLYLINE")
            ; entity selected was not a polyline, try again
            (progn
            (prompt " Entity selected was not a polyline.\n")
            (setq tpath nil)
    (eval 'tpath)
(defun formprint (vertpoint fname / flag)
    ;  This function takes a list of 3 reals and formats
    ;   the output in XYZ CNC form XXX.XXXX with leading
    ;   but not trailing zeros truncated.
    (setq flag true)
    (if (/= (car vertpoint) oldx)
        ; x value has changed, print new value
        (progn
            (setq oldx (car vertpoint))
            (setq flag false)
            (princ "X" fname)
            (princ (rtos (car vertpoint) 2 4) fname)
    (if (/= (cadr vertpoint) oldy)
        ; y value has changed, print new value
        (progn
            (setq oldy (cadr vertpoint))
            (if flag
                (princ " " fname)
            (setq flag false)
            (princ "Y" fname)
            (princ (rtos (cadr vertpoint) 2 4) fname)
    (if (/= (caddr vertpoint) oldz)
        ; z value has changed, print new value
        (progn
            (setq oldz (caddr vertpoint))
            (if flag
                (princ " " fname)
            (setq flag false)
            (princ "Z" fname)
            (princ (rtos (caddr vertpoint) 2 4) fname)
    (if flag
        (princ "\n" fname)
(defun C:CNCOUT (/ vertex path name outfile ourpt oldpdmode oldpdsize)
    ;  This funtion asks the user to select a polyline
    ;   to convert into ASCII coordinate data.  The data
    ;   will then be written to the user specified file
    ;   in XYZ compatible format.  The user will then
    ;   need to do only minor editing on the cnc file.
    (setq    oldx nil
            oldy nil
            oldz nil
    )                                        ; initalize redundant move
                                            ;  signals
    ; get the CNC polyline
    (setq path (getpoly))
    ; got the polyline, now get a file to send the output to
        (setq name (getstring "\nFilename and extension of CNC Program: "))
        (if (setq outfile (open name "r"))    ; does file exist?
            ; file found
            (progn
            (initget 1 "Y N")
            (if (/= (getkword "File exists.  Overwrite (Y/N)? ") "Y")
                ; user doesn't want to overwrite it
                (progn
                (close outfile)                ; close file and retry
                (setq name nil)
                ; ok to overwrite it
                (close outfile)
    ; got a name for the output file, open it for writing
    (setq outfile (open name "w"))
    (princ "% \r" outfile)         ; header for cnc file
    (princ "G70 \r" outfile)    ; dimensions are in inches
    (princ "G91 \r" outfile)    ; relative mode
    (princ "G0X0Y0 \r" outfile)
    (princ "M04 \r" outfile)        ; M04 - Cut on
    (SETQ kerf (GETSTRING "\kerf - None, Left or Right <N or L or R>: "))
        (IF (OR (= kerf "N") (= kerf "n"))
             (progn (princ "\r" outfile)     ))    ; No kerf
        (IF (OR (= kerf "L") (= kerf "l"))
             (progn (princ "G41 \r" outfile) ))    ; Left kerf
        (IF (OR (= kerf "R") (= kerf "r"))
             (progn (princ "G42 \r" outfile) ))    ; Right kerf
    ; save the current point style and size, and change it to ours
    (setq oldpdmode (getvar "PDMODE"))
    (setq oldpdsize (getvar "PDSIZE"))
    (setvar "PDMODE" 3)                    ; set point style to an X
    (setvar "PDSIZE" -3)                ; and its size to 3% of screen
    ; create a point in the database to use
    (command "point" "0,0,0")
    (setq ourpt (entget (entlast)))
    ; got a polyline and a file so... step through the verticies, and
    ;  output each to the print formatter.
    ; we will get the next vertex and also check to see if we are
    ;  finished in the test expression of the while loop
    (while (/= (cdr (assoc 0 (setq path (entget (entnext (cdr (assoc -1 path))))))) "SEQEND")
        (progn
            (setq vertex (cdr (assoc 10 path)))        ; now get its coordinates
            (setq ourpt (subst (cons '10 vertex) (assoc 10 ourpt) ourpt))    ; update progress
            (entmod ourpt)
 &n
