how long should the pipe be in order to cool the air by this amount?
Air of temperature 80 F enters a copper tube with inner diameter of 2 mm. The copper tube is of fixed temperature of -50 F.
Air speed is 8 m/s in order to get the flow rate I want.
How long should the tube be in order to cool the air to at least 0 F when it comes out of the end of the tube?
I'm an electrical engineer so this is not an area I'm familiar with. I don't need an exact answer, a ball park figure will suffice. Thanks
RE: how long should the pipe be in order to cool the air by this amount?
Nusselt number =Nu = 0.023 * Re^0.8 * 0.75^.33 = 190,000
Is that even close?
rho*Pi*D^2/4*cp dT/dt=h*Pi*D*(Tw-T)
or
rho*D/4*Cp/h*dT/dt+T=Tw
rho = gas density
Tw wall temperature
Cp=specific heat
D=diameter
h=film conductance
t= time to reach Temperature
For convenience,let
Q=rho*D/4*Cp/h
The solution
T=Tw+(Ti-Tw)*e^-(t/Q)
For any value of gas temperature T, you solve this for t
Now since
x=vt
x is the distance down the pipe that coincides with the temperature you reach
