Whats the value of bachelors of drafting and design
H everyone,
I earned my associates in drafting and design a few years back and I have been working as a designer for about eight years.  A local university has a bachleors of design graphics engineering technolgy.  I am considering going back to school for this degree but I am concerned about the worth of such a degree.  The program is ABET accredited and the university is tranferring most of my associates credit hours.  I just wonder if there is a value in this or is all the value in just haveing a bachelors degree itself regardless of the topic.  Any opinions will be greatly appreciated.
RE: Whats the value of bachelors of drafting and design
In engineering, most of the value seems to be in having your bachelors in Engineering.
While it varies some by industry & how good you are, designers tend to get looked down on a little.
That's not to say it's not worth getting, but it's probably not going to prepare you for an engineering position.  How far can you go with a more advanced design degree in your field/area?
An alternative that may be of value might be getting GD&T certification or something.  GDTPS aren't that common.
There is still a market for folks with good GD&T skills without needing a bachelors for checking or senior designer etc. roles.  Most of these positions require more experience than you have but having explicit GD&T certification may help.  I've known several checkers over the last few years making a good chunk that I was at the same time.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thanks Kenat,
Actually, I am working on several certifications.  GDTP being one of them.
If it's ABET accredited, almost any BS degree will get you a job easier. As KENAT mentioned, it may not be as an engineer.
Go for it and good luck!
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
