Is VSD like a transformer
Hi
I am not a VSD expert and so need some clarification regarding the following please. I have 375kW motor being fed from an 11kV bus via a VSD. On the single line diagram is states "VSD 11/3.3kV"? Does this mean that the VSD acts like a transformer and that it is a 3.3kV motor?
Thanks.
Thanks.
RE: Is VSD like a transformer
So the motor voltage can be different than the supply voltage to the VSD in this case.
David Castor
www.cvoes.com
Kind regards.
