Assigning Density of part without opening them
I'm trying to find a macro or add-in for solidworks 2010 x64 so that I can see and modifiy (if necessary) density of a part without opening each of them one by one. Best thing would be to be able to modify the property while browsing in an assembly....
Any suggestions?
Thanks!
Tony
RE: Assigning Density of part without opening them
In SWX2010 you can push properties back into a part file from a BOM in an assy.  I haven't tried this for the density, but if you make it a property of the part that shows up in the BOM table then you can double-click it and change it, pushing that change back into the part.
- - -Updraft
Tony, the macro Dustin pointed to was written by me. So if you need I can try to edit it.
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
Thanks for your help everyone, problem solve!
This forum is so helpfull,
Tony
