Can pipes be used??
Can pipes be used??
Can pipes be used??
I wonder wether pipes can be used in Heat Exchangers(Boilers). Since pipes have got greater wall thickness than pipes, I guess they wont be efficient for heta transfer. But wat if pressure requirements r there??
Thanks for ur opinion :)
RE: Can pipes be used??
What? Do you mean tubes and/or pipes?
Anyway, as far as pressure requirements are concerned, what makes the decision is the standard that rules out the construction: under ASME VIII both pipes and tubes are available, you need only to choose the specification.
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
I wonder wether pipes can be used in Heat Exchangers(Boilers). Since pipes have got greater wall thickness than tubes, I guess they won't be efficient for heat transfer. But wat if pressure requirements r there??
