Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...(I) have been able to get my problems solved from past messages and also new posts that other users have responded to promptly..."
Geography
ghoshtathagata2000 (Industrial)
27 Jul 10 8:21
Could anybody explain whether there the pressure drop would vary depending on the dust accumulated near the bottom in case the dust removal is not fast enough.
Is it possible to monitor the separation efficiency using a differential pressure instrument.
ash9144 (Chemical)
27 Jul 10 10:40
If your separator is accumulating solids then yes you're dP is going to increase.  You are then using part of your separation area for storage of solids and restricting your flow.  Differential pressure is very common measure of gas phase separation performance.
maranathatech (Mechanical)
11 Aug 10 13:38
Cyclone pressure drop for a cyclone separator is usually measured from (air/material) inlet to air outlet. The material discharge does not effect the pressure drop, unless the cyclones "plugs up" and incoming material cannot drop out.
For monitoring efiiciency, the cyclone manufacturer should have specification on expected pressure drops at various air volumes across the particular cyclone. Install a magnehelic or photohelic pressure gauge across inlet/air outlet to monitor the desired pressure drop at highest efficiency.
Helpful Member!  rmw (Mechanical)
11 Aug 10 20:59
Unless your build up got way up into the cone separation section, it shouldn't matter.  The vortex isn't designed to go all the way to the outlet because if it did, it would re-intrain the dust trying to leave.  There is, however, a point at which the vortex action would begin to be affected by the dust level in the bottom and that would hurt the efficiency more than the pressure drop.
rmw
Close Box
Join Eng-Tips® Today!
Join Us             Close
