CanBus PLC from which company
Hii
I am looking for a PLC which has an embedded CanBus port on CPU module. I do not want to use any additional communication module like siemens etc brands.
In fact I have a wireless remote control systems which transfers all its commands via CanBus. I want use a CanBus PLC to drive the digital outputs. But the solution should be competitive.
Would you advise me which brand of plc has this cpu?
thanks
RE: CanBus PLC from which company
Main one that comes to mind is Wago.
I've been looking for a comms solution based on CanOpen for a while now, it would appear that AB has nothing (including Prosoft options), Omron had it at one stage but no longer seems to support it, and not sure about Siemens.
Have a look at the Horner PLC's, they have CanBus built in.
I have used the WAGO system with CANBus many times. It is competitive, powerful and versatile.
750-837 - CANBus PLC
750-337 - CANBus Remote IO coupler.
