Ray Tracing Software
I would like to import 3D files of large plate type models with curvature into some sort of ray tracing software.  I would like to calculate focal lengths and things of that nature.  Does anyone have experience doing anything like this?  Thanks in advance.
RE: Ray Tracing Software
You will probably have better luck in this forum.
http://www.eng-tips.com/threadminder.cfm?pid=386
For optical modeling software I have used Zemax.  CodeV is also popular.
Since you posted in the finite element forum it might be helpful to check out SigFit which acts as a middleman between FEA and optics codes.
Optis is a simpler optics code that is embedded in CAD packages like SolidWorks.  It seems primarily suited for design of headlights instead of telescopes.
I hope this helps.
Rob Stupplebeen
