Does High Humidity Cause Low PSI
I am having trouble getting an epoxy grout to come to design strenth The material is conditioned for a hot weather pour What about the high humidity in the part of the country where the pour is occurring (SW VA/East TN) The grout is achieving 2000 psi less than jobsite engineering spec and nearly 5000 psi less than the grout supplier spec. Any ideas?
RE: Does High Humidity Cause Low PSI
Dik
