Multiple PWHT allowed
I had a PQR(P1G1 TO P1G2)done with 2 Hrs soaking time.I build a spool(CS, A105/A 106 Gr B) which has gone for 2 Hrs soaking time as well.Now customer wants me to weld a mounting on the spool.As per customer spec PWHT is needed for Min 2 Hrs.Service is sour.NACE MR0175 is applicable & max production hardness allowed is 200HB.
What I will need to do now?
Shall I weld the mounting on spool & do a localized PWHT for 2 Hrs again.By this way, one of the portion of spool will have a pwht for 4 Hrs.Will my existing PQR with 2 Hrs PWHT will support this?I have never done pwht beyond the PQR time earlier.
As NACE MR 0175 is involved i heard that production piece should go for same pwht cycle as that of original PQR coupon. is it true?
RE: Multiple PWHT allowed
Is your PQR qualified in accordance with ASME Sec IX?
Is the WPS impact qualified?
The PQR is also qualfied with impact test.But the spool piece here does nor require imapact test.
If impacts are not required for this application, your PQR will support a WPS with additional PWHT cycles.
I don't believe the additional PWHT will conflict with NACE MR0175.
Remember this is a minimum requirement and should not be construed to indicate that PWHT is not a crtical process. Your customer may have more stringent requirements.
