National Pipe Thread
I am not completely familiar with NPT. How do you read an NPT callout. I know we don't need to call out depth, as that is per machining spec.
The callout is a 1/8-27 NPT.  Is the 27 just referring to threads per inch? And since an NPT hole is tapered, is 1/8 the diameter of the inside part of the hole or the outside?
I just want to make sure of what I am getting made so I can purchase the proper fittings.
RE: National Pipe Thread
Got it.
A part that was touched on in the Wikipedia article, but was not mentioned is that the NPTF (National Pipe Thread Fuel) when used, can only be counted on for a leakproof connection one single time.  If the two parts are ever disassembled or backed off, they have to have sealing dope or tape applied to the threads to guarantee a liquid-tight seal.
Engineering is not the science behind building.  It is the science behind not building.
Thank you, Tex. During my research, I did read that somewhere as well (don't remember where). The parts shouldn't have to be disassembled--but in the even that they are, I will keep this in mind.
To answer your questions:
1) You just call out 1/8 NPT.  I like to put on 1/8 MNPT, "M" for male or Pin, 1/8 FNPT, "F" for female or Box, but I find the machine shops prefer not to use such identification on the prints.
2)the "1/8" is a nominal size reference and has no physical meaning.  The OD for this NPT geometry for example is 0.405 inches on the male.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
I've seen the MNPT/FNPT designation before, too.  It occurs to me, though, that one should be able to tell whether a thread is internal or external just bt looking at it.
I had a spec called out "FNPT", and I mad a point to clarify that it did NOT mean "NPTF". I think it is generally unnecessary to state male or female, except perhaps in a wholly written description of the parts involved where no other context would be available.
Mike
Metalonis has it right though, SnTMan, a casual glance at the print pretty much defines Box from Pin.  "F" and "M" are redundant as far as labelling goes.
Principal
The spec referred to couplings, but it was that kind of a customer...
