Adding Holes on an inclined surface
I'm trying to figure out how to put a counter-bored hole on an inclined surface that isn't normal to that surface. Instead, the hole is normal to another surface below the inclined surface.
Does anyone know how I can do this easily?
thanks,
windell
thanks,
windell
RE: Adding Holes on an inclined surface
If the normal direction is established by that lower surface, but it should be on a plane offset from that surface then your best bet is to first make the offset plane and select it before selecting the Hole Wizard.
- - -Updraft
-Dustin
Professional Engineer
Pretty good with SolidWorks
Thanks much!
windell
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
