high temperature pressure relief valves?
Thought this might be the best forum to ask for leads... I am looking for Pressure Relief or Safety Valve options for a vessel operating at 450 PSI and 750C, with pressurized syngas. The pressure does not seem to be a problem but the temperature is. Any thoughts on where I could start a search or options for this application would be appreciated.
RE: high temperature pressure relief valves?
450 C should be no problem.
Davefitz - possibly, I will look into this option.
