how do I use a union and bit fields ?
Hi, everybody, could you help me to answser my question?
Now I have written a program which uses single precision
floating-point(16-bits). However I need to reduce the precision of this from a 23b mantissa to 11 or 12 bits. So all my operations are programmed out into functions - add (float arg1, float arg2, float &res); sub...; mul...; div...etc. These functions first do the operation expected, then mask off the excess mantissa bits and adjust the rounding. It's for these latter manipulations that I need to get to the bit representation.
My problem now is that I need to take a 32b floating-point value, and then treat it as though it were just a string of bits.
Finally, how do I use a union and some bit fields if I want to access the fields in the number directly.
Here is my code:
void scale(const float &res)
#define f 12
#define m 0x000007FF
unsigned long r, t;
union {
unsigned long s;
float y;};
y = res;
t = (s&m);
s = (s>>(f-1));
r = (s&0x00000001);
s = (s>>1);
if (r==1){
if (t!=0)
s += 1;
else
if ( (s&0x00000001) == 1 )
s += 1;
s = (s<<f);
Here is my code:
#define f 12
unsigned long r, t;
union {
unsigned long s;
float y;};
y = res;
t = (s&m);
s = (s>>(f-1));
r = (s&0x00000001);
s = (s>>1);
if (r==1){
if (t!=0)
s += 1;
else
s += 1;
s = (s<<f);
